Hello,
I purchased this week a Seagate 2Tb ST2000DM001-1CH164, firmware CC24.
I did a couple tests with SeaTools and HD Tune Pro 5.0, everything looks normal, the HDD passes all tests... except when I try to actually transfert data from another interal drive to the new Drive, the transfert speed starts around 80Mo/s and quickly fall down to 40Mo/s or even down to Ko/s, until the Drive stop responding, every other file transfer in the computer get slowed down to similar speed (Even between 2 complete separate HDD), and ultimately, the drive disapear from windows until the next reboot.
Could it be an issue with the drive? or the Sata stuff transfert with my motherboard? This is way beyond my knowledge.
My current configuration is:
Proc: AMD Fx 6100 (6 core 3.3Ghz)
Motherboard: Asus M5A97 R2.0
Ram: Corsair 8Go x2
Power: Seasonic 650W 80+
radeon HD6870 VaporX
Hard Drives: Corsair SSD 120Go (operating system)
2x 320Gb Seagate Barracuda 7200.10 (ST3320620AS)
Windows 7
I tried to put the new HDD instead of one of my previous HDD and the problem persist. I am therefore fairly certain this isn't a cable or a power issue.
I also did a HDD Scan SMART report. You will find the result attached to the message. It shows some errors, but I have no idea what it mean exactly.
http://postimage.org/image/pwhscrynn/
Do you think I should return the HDD or is there something wrong with my computer?
Ram: Corsair 8Go x2
Windows 7
