Finding the right power supply model for my Small Tower...
lonewolf666
4
I am looking for a 300W-300+W power supply to fit in my small emachine tower. The dimensions for the current power supply are L=200mm x H=91mm x W=54mm [this is coming from an ebay ad i found he did not label the sizes but i have assumed this is what he meant.] If anyone knows the cheapest model to buy and where from i need you're help!
these are pictures of my power supply, and its specs on its side. please help.
http://i68.photobucket.com/albums/i15/lonewolf060/B6659L.jpg
http://i68.photobucket.com/albums/i15/lonewolf060/B6659.jpg
g048989h
280
Your PSU maybe a proprietary unit avaialble only at an specialty dealer. You maybe able to find something with demensions that are close but then you'll have to see if the leads are the right ones. http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007657%20600014016%20600014011&IsNodeId=1&name=Mini%20ITX
The above link should take you to newegg.com where they have several mini atx supplies. but be aware that my experience with mass mfg pc's like your emachines is that some of them are specialty items.
I hope this helps
lonewolf666
4
yeah i went directly to the dealer who created the power supply after opening it up. but the dealer's site would not even let me view the specs of each power supply on adobe reader. it was delta electronics inc by the way. I'm pretty pissed but i have just decided to buy a low profile ready gp, and buy the brackets separate. this graphics card i bought is the galaxy geforce 8500gs i belive something round there, anyways it only uses up 70w which is amazing from some of the reviews iv seen for it. thanks for all you're help. take care.
