G
Guest
Guest
Hi guys im thinking of getting a new pc as my old pc has stopped working. The pc will be used mainly for word processing, streaming video and for my son to play world of warcraft (alot).
These are the componants I have put together with the links to novatech incase you need more details:
Processor
AMD Athlon II X4 630 Quad Core 2.8GHz Socket AM3 - OEM
http://www.novatech.co.uk/novatech/prods/components/processors/amdathlonx2andx4/AMD/X4630OEM.html
Motherboard
Asus M4A78LT-M AMD 760G (Socket AM3) PCI-Express DDR3 Motherboard
http://www.novatech.co.uk/novatech/prods/components/motherboards/amdam3amdchipsetmotherboards/Asus/M4A78LT-M.html
Hard Drive
Samsung Spin Point F3 SATAII 1TB 32MB Cache Hard Drive <8.9ms 7200rpm - OEM
http://www.novatech.co.uk/novatech/prods/components/harddrives-internal/sata500gbto1tb/Samsung/HD103SJ.html
Ram
Novatech 4GB (2x2GB) DDR3 PC3-10666C9 1333MHz Dual Channel Kit
http://www.novatech.co.uk/novatech/prods/components/memory-pc/ddr3-pc3-10666/1333mhz/Novatech/RAM-313334.html
Case
Novatech Galaxy III Case With 450w PSU.
http://www.novatech.co.uk/novatech/prods/components/cases/cases/Novatech/GALAXY3.html
Operating System
Microsoft Windows 7 Home Premium 64-bit DVD - OEM
http://www.novatech.co.uk/novatech/prods/software/operatingsystems/Microsoft/GFC-00599GFC-00977.html
This all adds up to about £350 which is about $550
I have chosen not to buy a cd/dvd drive as i plan on using my old one, i will update it later on. I would like to know whether all of these componants work together and if there is anything i have missed. Also i would be very greatful for any advice you could offer in terms of cheaper components i could use instead of the ones i have chosen (i am on a small budget and this is a little expensive).
Please give any advice you can as this is my first build and i am a complete novice at building computers
Thanks in advance for any advice
Scott
Processor
Motherboard
Hard Drive
Ram
Case
Operating System
Scott
