Solved
First Build Have a Few Questions!
Hi this will be my first time building myself a gaming rig, i went AMD for the prices since they basically do the same thing and overclocking is always optional as well.
Basically i would like to know if the power supply that comes with the case i have selected will work good enough with the gpu and other hardware for a week until i can find one to replace it, if it doesn't have the right connections or it might damage my hardware please let me know.
Also is there a significant difference in performance between ddr2 and ddr3 RAM?
Here are the components i have selected for my build. Please give me some feedback if you see anything that may conflict :).
Motherboard
CPU
RAM
GPU
Case + PSU
5 answers Last reply Best Answer
More about first build questions
  1. Best answer
    Much better case
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811119233&Tpk=haf%20912
    Much better power supply
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005&cm_re=tx650-_-17-139-005-_-Product
    Don't even think about getting last-gen Ram.. it's the same price and everything.. not a HUGE difference but there is a big one ;)
  2. Hmm that sits me at $831..., suppose I'd have to wait another weak with those replacement options.
    I noticed the PSU claims it's crossfire ready, i don't think it'd be able to power two 5850's though would it?
    The Corsair 650 should be fine for 2 x HD5850s.
  4. Thanks for the switch ups Mr Pizza, and you too anort3 for sorting the future crossfire out :)
  5. Best answer selected by xUrbanx.
New Build Systems Product
