Closed Solved
Wireless card or adapter recommendation
Doesn't have to be N, I'm on a G network right now. Biggest thing is i need one with good range. I've had some really different experiences with adapters, some of them work great others i have to be in the same room as the router, hoping someone can suggest a good one. prefer to buy from newegg.
4 answers Last reply Best Answer
More about wireless card adapter recommendation
  1. Best answer
  2. you're right, that is a god card :) but i'm looking for something less expensive, like maybe in the $20 range. has to be <$30
    thanks
  3. Best answer selected by fatherhudson.
  4. This topic has been closed by Maziar
Wireless Routers Components Product
