Im not sure exactly which section to post this in ( here or Windows 7 ) , so i will post it in both .
I recently installed an xp upgrade to Windows 7 . The install went smoothly enough but when i ran a hardware analsysis tool i found an anomoly . The CPU speed was fluctuating from 1000 Mhz ( when idle ) up to its normal speed of 2900 Mhz at 50 + % usage . Now the only reason i am unsure if there is a problem is because whenever i ran the same tool with XP , there was no fluctuations , if any , by one or two HZ . So i was wondering if anyone with more experience with Windows 7 would give me some advice . Thanks in advance .
I dont know if specs on the PC are relevant , but here they are anywas
AMD Athlon 64x2 Dual core processor 5600+
AMD A740G M2+ Motherboard
4 GB Ram
4 GB Ram
