. 1 CORSAIR CMPSU-650TX 650W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 ...
Item #: N82E16817139005
Standard Return Policy $94.99
. 1 Seagate Barracuda 7200.11 ST3320613AS 320GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Item #: N82E16822148316
Standard Return Policy $49.99
. 1 LG 22X DVD±R DVD Burner Black IDE Model GH22NP20 - OEM
Item #: N82E16827136144
Standard Return Policy $24.99
. 1 COOLER MASTER HAF 932 RC-932-KKN1-GP Black Steel ATX Full Tower Computer Case
Item #: N82E16811119160
Standard Return Policy $139.99
XFX HD-577X-ZNFC Radeon HD 5770 1GB 128-bit DDR5 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Video Card
Item #: N82E16814150462
VGA Standard Return Policy $167.99
. 1 CORSAIR DOMINATOR 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMP4GX3M2A1600C9
Item #: N82E16820145296
Memory Standard Return Policy $127.49
Shipped from NJ, USA - Tracking #: KCV000021446
. 1 Intel Core i5-760 Lynnfield 2.8GHz LGA 1156 95W Quad-Core Desktop Processor BX80605I5760
Item #: N82E16819115067
CPU Replacement Only Return Policy $214.99
. 1 ASUS P7P55D LGA 1156 Intel P55 ATX Intel Motherboard
Item #: N82E16813131404
Standard Return Policy $149.99
OK so thats my build. I installed everything correctly, been running now for about a month. No problems at all no errors ect.
I am new to buildings rigs as this is my first time, its all stock no OC no nothing.
Reason I am posting is because today I decided to put my rig up against my brothers to see how fps would compare, and I was shocked to find my rig only gained like 5 fps over his.
Test on SC2, full settings same resolution 1280x 900 or something same tutorial everything same. i hit 46 FPS he hit like 40.
BUT his rig is like 2 years old. Only 9800 gt vid card 4 gigs ram but lower end stuff, and a duo core 2.8. so how is it possible for him to hit same fps i do?
is my system not performing as it should? other tests? i can do to see if i am running good numbers? slightly concerned now..
