HI i'm making a new computer build and I need some steps on finalizing the final components and I have come to stump and not sure what to choose at this point for the harddrive, cd/dvd burner, power supply and cpu fan. I using the following website to make all my purchases:
www.canadacomputers.com
I am hoping someone can help me with choosing the following components from the website:
1) Hard-Drive
2) Power supply
3) CD/DVD burber
4) Heatsink CPU fan
Below is the list of what I have chosen so far:
Hardware
CPU - AMD PHENOM II 965 $174.99
Motheboard - Asus Crosshair IV Formula Socket AM3 AMD 890FX $244.99
RAM - G.SKILL Ripjaws Series DDR3 1600MHz (PC3-12800) 4GB (2x2GB) Dual Channel Kit (F3-12800CL7D-4GBRH) $132.99
Graphics Card - ATI 5870 graphics card
http://www.canadacomputers.com/product_info.php?cPath=4... $424.99
CASE - Cooler Master HAF X Full Tower Gaming Case (RC-942-KKN1) $169.99
Below is a template of what I intend the system to do:
APPROXIMATE PURCHASE DATE: Wish to build and assemble within 1 month after proper research has been done & recommendations have been given.
BUDGET RANGE: $1000 to $2000 - Would like to keep this in the $1500 dollar range with taxes if possible but can stretch to $2000 or even a bit more ($1700 to $2000) if it makes sense to spend more on a part or component. Example why purchase a AMD Phenom II X4 955 Black Edition (125W) Quad Core Socket AM3, 3.2GHz, 8Mb Cache, 1800MHz HT, 45nm for $159.99 when you can get a AMD Phenom II X4 965 Black Edition (125W) Quad Core Socket AM3, 3.4GHz, 8Mb Cache, 1800MHz HT, 45nm for $179.99 and get an extra 200Mhz of processing speed.
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT:
This is what I would like to do on this system
Single Bootable System (Windows XP Professional or Windows XP Home Edition or Windows 7 Professional Edition)
Duel Bootable System (Windows 98 & Windows XP Professional) - Not even sure if this is possible on a 64 bit chip
Duel Bootable System (Linux Fedora & Windows XP Professional)
Duel Bootable System (Linux Fedora & Windows 7) - Considering buying Windows 7 at this time as Market seems to be changing
Internet Explorer Browsing
High End Graphic PC Gaming
Microsoft Word, Powerpoint, Access, Excel
Outlook Express Email
Regular Email (Example: google, yahoo, etc)
Downloading/Uploading Streaming Video
Music Player
Computer Programming (Visual Basic, C++, Java, Perl, HTML/XHTML)
Viewing youtube videos
Flash player capable
MSN/AOL Messenger
Ventrilo
Games to be played on System: Counterstrike 1.5, Counterstrike Source, Bad Company 2, Any high graphic end first person shooter game that
comes out later in future. Would like to make certain that this system will be able to play any future games.
Antivirus/Firewall Capable (Use to use Nortons, It was a bottle neck on the system I have. Had to remove it)
Server Capabities (Later on would like to use this a server for home network or set up as a counterstrike server room for friends for online
play)
PARTS NOT REQUIRED: Monitor, keyboard, mouse, speaker, Operating System (Win 98, XP, Fedora)
PARTS REQUIRED:
CPU
Motheboard
Graphics Card
Sound Card (Not sure if i need one)
Memory
IDE Hard Drive
Power Supply
Computer Case & Fans
Heat Sink
DVD/CD Burner
Floppy Disk (If possible - Yes I know its not used anymore but would hope for it)
Cables to connect all parts together? I hear usually nowadays this all comes with the parts you buy.
PREFERRED WEBSITE(S) FOR PARTS:
www.canadacomputers.com - Or any other website that has good prices to order from for Canadian dollar.
COUNTRY OF ORIGIN: Canada, Ontario
PARTS PREFERENCES: AMD
OVERCLOCKING: Yes
SLI OR CROSSFIRE: Yes if it would help save money or improve performance.
MONITOR RESOLUTION: Using a SyncMaster 931w with 2000:1 Dynamic contrast. Using windows XP Pro with the following settings at 1152 x 864
ADDITIONAL COMMENTS:
Computer needs to be able to do multi-tasking with multiple windows open without freezing or clogging.
Ablility to ALT TAB out quickly launch or access programs
Ability to quickly use Fast User Switching Mode on Windows XP
Computer Fans Need to be quiet (Friend has a computer and sounds like a vacuum cleaner/airplane combo when turned on - don't need this)
Low to moderate power consumption if possible
Something that will suit my needs and will continue on in future for quite sometime.
Any addition items that would prove to be useful please list them that should be considering when making a computer.
Ability to easily upgrade or replace parts as newer components hit the marketplace.
