Hello,
I recently purchased an HP Dv6 7040TX model and i created Recovery Disc using the Software given by the manufacturer HP Recovery Manager.
However the Laptop came with 4 Partitions.
My HDD is 750GB.
All Primary Partitions:-
1) System 199MB
2) C (Main Boot Volume) 676GB
3) HP Tools (FAT 32) 102MB
4) D:Recovery (21 GB)
I want to however create or atleast 3 other partitions for my use,can you please help me on this?
I cannot shrink C and create 3 other partitions until and unless i get rid of other three and even the strange think is that whenever i shrink C it only shrinks out 333GB and almost rest in left in C,i don't wanna take risk with my new Laptop and neither can i affford any more expenses on any other stuff.
I was thinking of removing The D drive (recovery) since i made the recovery discs,there is even an option to remove that drive through Hp Recovery Manager but it says once removed i wont get the F11 (System Recovery) option now i didnt get that and it kinda looked scary so i didnt do anything with it.
I was thinking of Merging the Partitions using Easeus Partition Master Home Edition the "Hp Tools" and "System" partition,but then it occured to me that HP tools was FAT 32 will it work,i was not sure,will it screw up!?!
Then maybe merging "System" with "C"?
OR
D:Recovery with HP Tools ?!?!
I was thinking of Converting MBR with GPT...
If that is better option can you give me the instructions step by step on how to do it ?
Can you please be kind enough to give your suggestions i dont know what to do,awaiting your response.
Thank you for taking time to read my Post.
My HDD is 750GB.
1) System 199MB
OR
