Sd card format problem
Hello, when i insert my memory card it show's in my computer. but when i command format it show's unable to complete format successfully.
what should i do ?
3 answers Last reply
More about card format problem
  1. SD cards should be formatted in the device that you use it (camera, MP3 player, ect.)
    The problem is that I can't write the Raspbian OS for my raspberry pi onto the SD card because the space is too small. So I don't really see a way around that. I could see if Win32diskimager (the program used to put the image on the SD card) could do it, I'll have a go now :)
  3. You may need a new card.
  4. rgd1101 said:
    thank you for your advise.
    but it showing : the memory card is right protected.
    please release the right protect switch.
    BUT it no right protect switch !
Flash Media Memory Card Computer Format SD Card Command Prompt Storage
