I am building a New workstation computer for my home business. I have an existing hard drive installed with windows 7 32 bit that I will use in my new build.
I need some help to make sure all my parts will fit together and work properly, as well as any money saving tips. The system will be an AMD system, because I am trying to get the most bang for my buck and I have had good experiences with AMD in the past.
So heres my computer at the moment.
CASE AND POWER SUPPLY
Antec 300 & 650 Earthwatts Power Supply $130
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.514534
I am also considering the cheaper option
Coolermaster HAF 922 & Coolermaster GX 650 watts Power Supply $110
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.523825
CPU AND MOTHERBOARD
AMD 3.2 Phenom II x 4 & ASUS 790GX ATX Motherboard $220
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.526569
I have a similar setup now in my current computer and so I figured I would stick with what I know. Open to suggestions though.
VIDEO CARD
Sapphire ATI HD 5770 1 GB $125
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102873
RAM
Gskill 4Gb DDR 3 $87
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231277
DVD Drive $20
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
grand total after tax and shipping and rebates, just under $650
I just want to make sure everything will go to together okay and there will be enough power for the system. Plus if anyone can make any improvements to the system or have seen any better deals through combo's
I really wanted to keep it under 600, but I'm not sure I want to step down to the Athlon/less cores, cheaper motherboards, graphics card or less ram. The only place I can see any real savings is the case
CPU AND MOTHERBOARD
VIDEO CARD
RAM
DVD Drive $20
