hi im currently using a micro ATX silverstone Sugo SG04-F [
http://www.silverstonetek.com/products/p_contents.php?pno=SG04-F&area= ]
been using it for around 9 months , and its fine, but the airflow within could be alot better, currently i have two large intake fans at the front, and a silverstone case flow fan at the back [http://www.silverstonetek.com/products/p_contents.php?pno=fx121&area=usa]
now what i find strange is, at the back, no air is being extracted from my ocz power suply, regardless of how hot things get, the caseflow pumps it out, and the graphics card temps are fine,
i having slight issues with cpu temp there higher then id like and sometimes effect performance and cant be good long term
so im loooking for a psu which will help this situation, ones with short thin wires, and that is small and will extract the hot air off the cpu directly below it,
around 600 watt, AMD motherboard socket AM3 [938], phenome II x4 995
thanks
thanks
