Please Review My i7-950 System
Hi,
Wondering if the group could please sanity check my config. Use will be photo & video viewing & editing. Light gaming.
CASE: CoolerMaster 690 II Advanced Mid-Tower
CPU: Intel i7-950
Cooling Fan: Intel LGA1366 Certified CPU Fan & Heat-sink
Motherboard: Asus P6X58D-E Intel
Memory: 6GB (2GBx3) DDR3/2000MHz Triple Channel Memory
Video Card: ATI Radeon HD 5770 1GB
Power Supply - Corsair CMPSU-650TX 80 Plus
Hard Drive: SATA-III 6.0Gb/s 64MB Cache 7200RPM
Optical Drive: Pioneer BDR-205
Thanks for your help.
-Ralph Warren
3 answers Last reply
More about please review system
  1. 1. What OS will you use?
    2. Are you going to overclock? If so you need a good aftermarket cooler. Even if you aren't overclocking it is still recommended .
  2. It will be Windows 7.
    An upgraded cooler sounds like a good idea. Not sure about over-clocking but good to have the option.
    Is liquid cooling the best option or just a good fan/heat-sink?
    Thanks for your help!
  3. 2000mhz memory is only usable with overclocking.. that MOBO supports 1600/1333/1066 native so switch to 1600mhz
    Asetek liquid cooling is just like the corsair h50. I like them both.
Cyberpower Systems
