Hello,
i bought one new PC with following configuration ::
CPU : AMD PHENOM II X2 550
MOTHERBOARD : M4N68 T-M
RAM : TRANSCEND DDR3 1333MHz
GRAPHIC CARD : XFX NVIDIA 250GTS 1GB HDMI
MONITER : SAMSUNG B2230
SMPS : ZEBRONICS 500W DELTA SERIES
THE PROBLEM IS ::
"WHEN I CONNECT THE 24-PIN DVI CABLE TO MY MONITER AND TURN ON THE SYSTEM THE DISPLAY ON MY SCREEN IS "ANALOG-DIGITAL-ANALOG-DIGITAL" AFTER THAT IT SHOWS "CHECK SIGNAL CABLE".......WHATS THE PROBLEM. IS THERE ANY PROB. WITH GRAPHICS CARD OR MONITER.......PLZ GIVE AN URGENT SOLUTION
THE PROBLEM IS ::
