PC Build help
Okay, so I just built a new PC for myself.
I turn it on, all the fans come on - the case fans, CPU fan, video card fan..., the DVD player opens, the HDD seems to be running...
but the (non-USB) keyboard, USB mouse and monitor are not responding to the system. No blinky lights, no nothing. Also the power LED doesn't come on, even though I am pretty sure I have it plugged into the right place on the MB.
What didn't I connect correctly? HELP!
2 answers Last reply
More about build help
  1. Ask a friend to check to see if you have everything connected properly or bring it to a computer shop and ask them if everything is connected properly. It sounds like you didnt hook everything up.
CPUs
