Hard-drive for current build and new build
Hi everyone!
Just want to say thanks in advance for anyone that gives their thoughts, it is very much appreicated.
I wanted advice on what hard-drives(s?) to get for my current build :
Processor:Intel Core 2 Duo E6700 @2.66GHz
Motherboard5N32-SLI SE Deluxe
[http://uk.asus.com/Motherboards/Intel_Socket_775/P5N32S...]
Power supply: FSP Group FX600-GLN 600W ATX V2.2/EPS12V SLI Certified CrossFire Ready Active PFC Power Supply
Memory: Corsair 4GB DDR2 800MHz Memory
GPU:SapphireRadeon HD 7870 GHz Edition OC 2GB
Monitor resolution:1600x900
And for my new build. My battleplan is to upgrade each component piece by piece over the next 6 months to relax the cost, into a new gaming computer. My thought is to buy both a SS hard-drive for gaming and a 500GB normal one for storage, ive looked around and i have no idea on which HD's would acually work with my current MoBo and power supply and new power supply and MoBo that i havent bought or looked at yet...Im not sure if this would be a problem at all.
I would say that a £80 budget for SSD is realistic but no idea on the other and this budget is based on my limited knowedge of SSD's so again, any advice is very welcome.
Cheers!
