Hello everyone,
Long time reader, but first time poster to the forums. My MOBO on my home-built system just crapped out on me, and I'm taking the opportunity to upgrade from my current AMD Athlon 64 X2 6400+ setup to an LGA 1366 Core i7 rig. I accidentally ripped the door off of my old XG Quantam case a while back too, and now the front panel LCD doesn't work anymore, so I'll be building in a new case as well. Hoping to target somewhere around the $1000 price point for the rebuild. I don't exactly have a tight budget, but am looking for "best value" gaming rig (don't plan to do much overclocking now, but may in the future as a cheap "upgrade").
At any rate, I've put down a couple of options for each component along with the price, and wanted to get your guys opinion on which way I should go. I've already got a preference, but thought I'd put it out there for public consumption. See below for the complete list of alternatives, and then vote in the poll for one of each component that you prefer. I've also given the option to vote for "other". If you do that, then please post a comment with your suggestions.
Here are the current components that I'm transferring over to the new rig:
GPU:
EVGA 01G-P3-1373-AR GeForce GTX 460 (Fermi) Superclocked EE 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
Storage:
1 x Corsair P128 CMFSSD-128GBG2D 2.5" 128GB SATA II MLC Internal Solid State Drive (SSD)
2 x Western Digital Caviar SE WD2500JS 250GB 7200 RPM SATA 3.0Gb/s 3.5" Hard Drive -Bare Drive
Optical Drives:
2 x SAMSUNG 22X DVD±R DVD Burner Black SATA Model SH-S223Q LightScribe Support
I'm pretty sold on going over to the dark side of Intel, but I've had an AMD rig for the past 6 years, so I'm a little remiss to leave them. But from what I've seen, it's pretty clear that Intel has taken over the title for best CPU. Would like to hear your OBJECTIVE thoughts between the two (leaving the fanboyisms at home).
That being said, I'm going to proceed assuming the CPU and MOBO are set (though feel free to suggest alternatives if you have an opinion either way.
CPU:
$299 Intel Core i7-950 Bloomfield 3.06GHz LGA 1366 130W Quad-Core Processor
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115211
MOBO:
$209 GIGABYTE GA-X58A-UD3R LGA 1366 Intel X58 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128423
So here's the components I'd really like your opinion on:
RAM:
$399 CORSAIR DOMINATOR 12GB (3 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145321
OR
$239 G.SKILL Ripjaws Series 12GB (3 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231356
I usually buy Corsair, but the cost difference between the two, and the fact that I've heard 1600 doesnt' make that much of a difference over 1333 has me leaning towards the GSkill. What do you guys think?
PSU:
$169 CORSAIR HX Series CMPSU-850HX 850W ATX12V
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139011
OR
$129 Thermaltake Toughpower XT TPX-775M 775W ATX 12V
http://www.newegg.com/Product/Product.aspx?Item=N82E16817153127
OR
$109 CORSAIR CMPSU-750TX 750W ATX12V
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139006
I plan to upgrade my GPU to an SLI setup sometime within the next two years so I want to build in room for expansion with my PSU. The $109 Corsair isn't modular which kind of sucks, but given the other specs is it worth saving the $60? What about the Thermaltake? Let me know what you think.
Case:
$139 NZXT Phantom PHAN-001BK Black Steel / Plastic ATX Full Tower
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146068
OR
$154 Thermaltake Element V Black Edition Steel Full Tower
http://www.newegg.com/Product/Product.aspx?Item=N82E16811133178&Tpk=Thermal Take Element V
I actually like the looks of the NZXT case, and the features on it look spectacular (wire management, tooless drive bays, space, etc.). But the Thermaltake was voted best by Tom's...but not tooless...don't know. Leaning very heavily towards the NZXT. Any other thoughts?
CPU Cooler:
Like I said, I don't really plan on overclocking immediately, but considering I may do it in the future and I've heard the stock heatsink and fan for the Core i7 950 is pretty bad, I've thought about getting an aftermarket CPU Cooler. I'm concerned about space on the MOBO with an aftermarket CPU Cooler, but wanted to see what you guys thought.
$0 Stock Intel heatsink and Fan
OR
$45 XIGMATEK Intel Core i7 compatible Dark Knight
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233029
OR
$70 Prolimatech Megahalems Rev.B CPU Cooler (cost includes fan not included)
http://www.newegg.com/Product/Product.aspx?Item=N82E16835242001
I could definitely stay stock at first, but how much of a pain woudl it be to install one of these aftermarket coolers at a later date? I'm thinking that would be a mess, which is why I'm considering going toward the "value" option of the Xigmatek. But the Prolimatech is at the top of nearly every review I saw and it's only like $30 more which is pretty small pickings considering the performance difference.
Any thoughts on this? (I ran out of space in the poll for the CPU Cooler)
Thanks in advance for all your help. I know this is a LOT of information, but thought I'd throw it out there and get some feedback from the experts before I dropped $1000-1300 on my next computer build.
GPU:
Storage:
Optical Drives:
CPU:
MOBO:
RAM:
OR
PSU:
OR
OR
Case:
OR
CPU Cooler:
OR
OR
