Hmmm... got a problem with my new build..
Last response: in Systems
I have built my first computer yesterday (it worked 3rd time thanks to Tom's Hardware
) and it was working fine. But after about an hour of it running the screen just went black. It sounded the same, the fans were still running. But nothing on the screen. If i turned it off and on it would turn straight back on working. I'm thinking its the graphics card but cant be sure.
Specs:
ASUS M4A87TD
AMD PhII X4 965 3.4GHz
430W Thermaltake PSU (I was thinking it might have been lack of power?)
4GB OCZ Ram (should be 1333MHz dont think it is though, help with setting it up in BIOS would be good too)
Amaze Raedon HD5770
Using a HDMI connection to a 32" TV (it said it was 1080i on the TV, i had my resoultion at 1368x780 (i think))
These problems have now stopped, I dont know if its because I switched to VGA or if its a coincidence. But even if i switch to VGA from HDMI when the screen goes black I still have to restart it.
Its not overheating either from what I can see, I've got a good case the (NZXT Gamma, I love it) its good awesome ventilation, 1 big fan, plus the Power Supply fan, Heat sink, and the fan on the Graphics card itself.
So if I could have some help with this that would be great,
Thanks Heaps,
Caius
) and it was working fine. But after about an hour of it running the screen just went black. It sounded the same, the fans were still running. But nothing on the screen. If i turned it off and on it would turn straight back on working. I'm thinking its the graphics card but cant be sure.Specs:
ASUS M4A87TD
Amaze Raedon HD5770
Thanks Heaps,
Caius
More about : hmmm problem build
From XFX's specs page on the 5770:
450 Watt or greater power supply with one 75W 6-pin PCI Express® power connector recommended.
If this is the PSU, it only has a single 12V rail with only 18 amps. Thats horrible for a modern machine that uses 12V for almost everything. My bet would be insufficient power causing the graphics card to cut out.
http://www.hardwaresecrets.com/article/Thermaltake-Pure...
http://www.xbitlabs.com/articles/cases/display/thermalt...
OUCH! Get it out of your computer before it damages something.
The main problem with this power supply is that it can’t deliver its labeled power. It is, in fact, a 350 W power supply. said:
The main problem with this power supply is that it can’t deliver its labeled power. It is, in fact, a 350 W power supply. http://www.xbitlabs.com/articles/cases/display/thermalt...
at a load of about 380W, the PSU’s switching transistor overheat and burned down in the power supply. It was so hot that the insulating plastic spacer under the screw the transistor was fastened with melted. said:
at a load of about 380W, the PSU’s switching transistor overheat and burned down in the power supply. It was so hot that the insulating plastic spacer under the screw the transistor was fastened with melted.Related ressources
- Hmmm didn't I predict this over a year ago - Forum
- Hmmm .. Off topic - Forum
- I got A real problem - Forum
- Problem with my new build - Forum
Generic power supplies can be anything from OK to fire hazards. It really depends on who manufactures them. I stick with quality brands so I know I am not going to have flakey lockups and such from fluctuating power or worse, destroy my other parts from bad overload protection. (Antec, Seasonic, Corsair, XfX, Silverstone, some OCZ, or anything I read a couple good professional reviews on).
Ok well i got my new PSU today.. It is a Ritmo 680. (680W)
I used my motherboards auto-overclock utility.. wouldnt post. (it went to 4.1GHz)
I overclocked it to 3.9GHz logged in graphics kept cutting out every 3 minutes for 2 seconds.
so now im back to defaults.
seems to be fine.
so reccommended solution to overclock?
is it my graphics (5770) stopping it or is there just not enough power?
seems to be fine.
Related ressources:
- ForumProblem with new build
- ForumPC radiation/distruptiom ( hmmm )
- ForumHmmm , another X-com inspired game announced...
- ForumGot a IVB i7 for xmas, time for a new build
- ForumASUS A7N8X hmmm ...
- ForumBad Memory? Or bad Mobo? Hmmm .
- ForumOverclocking. hmmm
- ForumNow we know who got Iraq's oil, Shell and BP!!
- Forumhmmm
- Forumhmmm ..... that wasn't supposed to break
- ForumBye Bye PC, Just Got PS3
- ForumNew build install problem
- ForumHTPC Mobo+CPU ~$150
- ForumShutdown Problem
- ForumHelp me pick my next build
- More resources
