Computer won't boot when 4pin CPU Power connector plugged in
- PC is not running when i plugged the 4-PIN cpu power connector !!!! Forum
- SolvedComputer wont boot when 12v 4pin is plugged Forum
- SolvedComputer wont boot when 12v 4pin is plugged. Forum
- CPU power connector (ATX12V , 4pin) cause boot problem Forum
- Computer won't boot with CPU power cable plugged in, fans spin for a couple seco Forum
- SolvedAccidently Plugged 3-pin fan connector into pins 2-3-4 instead of 1-2-3 of 4-pin socket. System won't turn on. Forum
- Computer won't start, starts when I unplug 12v 4-pin CPU connector Forum
- Computer won't POST with 4 pin power connector plugged in Forum
- SolvedAfter installing a new gfx card the computer wont boot past bios. The bios seems reset as well. I have plugged in the power Forum
- Solvedhow to connect 4pin cpu power connector with Corsair VS550 550 Watt PSU Forum
- PC won't boot when 4-pin ATX cable is plugged in. Forum
- Do I need to use the two 4 pin "cpu" power connectors if I'm using a 20pin + 4pin "p4" connector? Forum
- with 8 pin power plugged in cpu fan tries to start..without it everything spins up but wont boot Forum
- SolvedWill an 8pin power cord work on a 4pin cpu power connector? Forum
- Computer wont boot with 8 pin power plugged in Forum
- SolvedI plug in my cpu power to mobo and it wont boot Forum
- SolvedSandy Bridge i5-2500k with 4-pin CPU Power Connector Forum
- SolvedCPU Power Connector Wasn't Plugged In Correctly? Forum
- Does using an 8-pin CPU power connector on a 4-pin board result in less amperage? Forum
- Computer won't turn on when a specific PCI-E connector on the videocard is plugged in Forum
- More resources
Read discussions in other Motherboards categories
