Will this build work
Last response: in Components
wondering if this buld will work and if it dont plz let me know why and what i can switch out ty
tower = APEVIA X-CRUISER2-BL Blue SECC Steel ATX Mid Tower Computer Case http://www.newegg.ca/Product/Product.aspx?Item=N82E1681...
psu XION Power Real XON 1100W ATX
gpu = x2 EVGA GeForce GTX 580
motherboard= ASUS Crosshair IV Extreme AM3
cpu AMD Phenom II X6 1090T Black Edition
water cooling Thermaltake CL-W0121 2U Drive Bay Water Cooling System
http://www.newegg.ca/Product/Product.aspx?Item=N82E1683...
hdd x2 Seagate Barracuda 1TB 7200 RPM
http://www.newegg.ca/Product/Product.aspx?Item=N82E1682...
cd/dvd burner = SAMSUNG Black 22X
memery = x4 CORSAIR XMS 4GB 240-Pin DDR3
moniter =x3 ASUS Black 22" 2ms(GTG) Widescreen LCD Monitor
also if this build will work can i swap out the cpu listed for this cpu just to save money to get it up and runing for my self then will be buying the other cpu
AMD Athlon II X2 245 Regor 2.9GHz 2 x 1MB L2 Cache Socket AM3 65W Dual-Core Desktop Processor http://www.newegg.ca/Product/Product.aspx?Item=N82E1681...
plz discrib any issues new at building comps and wont a good system and comments to make it better will be apretiated
sorry for any spelling problems ty
lynmachine
More about : build work
That memory isn't on the Qualified Vendors List.
The Athlon II would be hard pressed to run a single 580 GTX.
If you are planning on SLI, whats going to run the 3rd monitor? If you're looking to do Eyefinity you need ATI GPU's
I would go for a single 580 with antec or corsair ps. Newegg has some gskill sniper 1333 2x4 gb kits for $75 shipped in their email promo. I use gskill, and it works fine.
so ya i wont eyefinity so ill change the gpu's to 1 Radeon HD 6970 "will it work ok?"
ic i have in 4 4gb 2000 pc3 16000 now the mother board i have the ram bus speeds are 1600/1333/1066 ok got u
now im asking what would be the diff ill notice between the 4x4gb1333 bus speed ram and the 4x4gb 1600 bus speed will i even notice a diff since there is 16 gb of ram ? if no diffance will this kit work good CORSAIR DOMINATOR 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 Desktop Memory Model CMP16GX3M4A1333C9
and as for the AMD Athlon II X2 245 2.9GHz AM3 65W Dual-Core the only reason i put that in is b/c if i can get the system up and running with that cpu id use it cus i have it for a short time till i get the money for the other cpu listed
ty also sorry for my spelling
ty to all who help trying to make my dream comp
sined Lynmachine
Related ressources
The gskill sniper is rated at 1333 for 1.5 volts; bumping up the voltage to 1.6 should enable it to run at 1600, but it's not guaranteed. I mixed my ripjaws with some old 1066 ram and both run at 1600, but I had to try numerous settings in the bios to overclock the old ram. 1600 is good for overclocking; you won't notice much difference otherwise. For the gpu, I can't help you; I'm not a gamer.
what if the ram im buying is 1333 at 1.6v can i still bump it to 1600 by uping he volage a bit
and other then that will the system work i have posted ty
i play games every day im runing a system it a accer aspire x1200 slim tower with a 220w psu a 2.6 duel core amd 5000+ and 3 gb of ram with a ati redion hd 5450 card O.C to 800 clock and 900 mem and im only getting about 23- 31 fps on low graphics runs choppy i wont this system so i can run it with high fps like 60+fps
and belive it or not with metro 2033 im getting the same fps on med graphics
ty to all who help
Lynmachine
As long as you can find it (CMP16GX3M4A1333C9) on the QVL then yes it will work well and has been tested, otherwise you risk an incompatability (although the risk is small it still happens often enough)
edit - Actually your best bet right now is to wait a few weeks. Sandy Bridge (Intel) cpu's just came out and prices will take a little time to stabilize possibly saving you some nice $$
There is no way a dual core processor will run an eyefinity setup. just look at the system builder marathon Tom's did when they used a dual core i3 and 2 GTX 460's. It couldn't even keep up with that let alone 2 6970's which is what I would recommend for gaming across 3 monitors. You are going to need some serious horsepower.
This is an older article but it shows that for 3 monitors at 1600 x 900 you need at least 2 GTX 480's and at 3 1080p monitors you needed 3 GTX 480's. I know those are 1 generation old but the bottom line is don't expect one card to run 3 of those monitors at high settings.
http://www.tomshardware.com/reviews/quad-sli-nvidia-sur...
Ask the community
