A aranzaldua Distinguished Sep 2, 2011 3 0 18,510 Sep 2, 2011 #1 I need the plastic housing that holds the heat dissipator for the CPU to the motherboard for a Pegatron m2n78-la motherboard. Can someone help?
Solution tecmo34 Sep 3, 2011 I believe this is what you are looking for... EVERCOOL K8-AM2-RM AMD K8 Socket AM2 Retention Holder
tecmo34 Administrator Moderator Jan 20, 2009 9,317 113 37,590 Sep 3, 2011 Solution #2 I believe this is what you are looking for... EVERCOOL K8-AM2-RM AMD K8 Socket AM2 Retention Holder Upvote 0 Downvote Solution
A aranzaldua Distinguished Sep 2, 2011 3 0 18,510 Sep 3, 2011 #3 I believe it is. Thank you very much for your help. You made it easy as pie. Upvote 0 Downvote
A aranzaldua Distinguished Sep 2, 2011 3 0 18,510 Sep 3, 2011 #4 Best answer selected by aranzaldua. Upvote 0 Downvote
