Are these parts compatible?
Last response: in Systems
Can someone please tell me if these parts are going to fare out to be the nice machine I plan to build for gaming?
Coolermaster Case Storm Scout black
Asus motherboard M4A87TD/USB3
OCZ PSU ModXStream Pro 500W
AMD CPU AM3 Phenom II X4 955 quad core 3.2GHz x4 Black Edition
G-Skill 2048 MB DDR3 PC10666 1333Mhz Kit CAS 8 (X4)
Gigabyte GeForce GTX 460 OC Edition 768MB GDDR5 PCI-E Dual-Link DVI-I SLI Ready DirectX 11
Hitachi 1TB hard disk drive 1000GB Deskstar SATA II 300 7200rpm 32MB
Microsoft Windows 7 Professional 64Bit
Your comments and advice is much appreciated,
More about : parts compatible
For gaming you are going to want to change that up a little bit. I wouldnt get 8GB of memory, especially not in the form of 4 2GB sticks, get a 2x2 kit it should cost you less than 2 2GB sticks separately. I would also pick a samsung F3 or a 1TB WD Caviar black (the 2FAEX not the 1FALS) they are two of the fastest drives available thanks to their 500GB platters.
The rest of it looks pretty good, but check for combos and switch the 460 for a 1GB model if you can, it actually provides more performance with the 460.
Ask the community
