Tom's Hardware > Forum > Windows XP > Configuration & Customize > System Restore and Removable Drive Problem
Forum Windows XP : Configuration & Customize - System Restore and Removable Drive Problem
Archived from groups: microsoft.public.windowsxp.configuration_manage,microsoft.public.windowsxp.perform_maintain (More info?)
I have a problem, repeatable, getting System Restore to work when
removable drives (in this case software based drives that are mounted
as needed). are used.
What happens is this. Even though the drives are tagged as DISABLED
within the system restore screen, they do not maintain that setting
from one boot to another, it's as if XP is unable to remember the
setting , even though the drive Letters are not being changed.
When a drive without 200 meg free is mounted, it disables SR and
all restore points are lost.
Does anyone have a solution to this annoying problem?
Sponsored Links
Hi Tom,
> work when removable drives (in this case software based
> drives that are mounted as needed). are used.
> as DISABLED within the system restore screen, they do not
> maintain that setting from one boot to another, it's as
> if XP is unable to remember the setting , even though the
Unfortunately, this is by design. See: http://snipurl.com/hcw6
> disables SR and all restore points are lost.
Regards,
Bert Kinney MS-MVP Shell/User
http://bertk.mvps.org
Reply to Anonymous
There are 507 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
