Hi, so specs first:
MSI GX 623// Intel Dual core P7350 2.0 GHz (Oc possible to 2.4)//4 gb ram DDR2 (3072 mb working, 32 bit system)// Ati Mobility Radeon 4670 512 MB ram GDDR 3// 500 GB 5400 HDD// Win7 Home Premium 32 bit.
Catalyst version: 10.7
Driver Versionriver Packaging Version 8.753-100706m-102501C-ATI
Now, my problem is White screen frezze with sound buzzing in all unreal engine based games.
All the tested games and confirmed same problem: GTA4,Gears of war,Singularity,Mass effect 1 (Mass effect 2 works just fine...),Unreal Tournament 3, Starcraft 2 (this alst one works well if all settings are set to minimum).
Now, some of those games crash into this white screen more often if they have high settings, others crash in specific places (mass effect) no matter the detail level, and some crash after a certain amout of time playing (UT3).
Anyone knows anything about this? I was trying to look for a possible answer, but since mobility arent oficially supported for games....
If i forgot to add any information, tell me.
P.S: i try to keep up to date most of my software, DitectX, drivers, etc.
Thank you for your help in advance!
