Hi,
I suspected that my PSU is dead, just like to confirm here before i make a purchase. Here are the signs.
I managed to turn on the computer once after a good two years without using it. It ran for like 30 secs (I got into the BIOS and was do some settings without saving) before the PC shut down by itself. No luck booting it after that.
With the PSU only connected to the mobo and the graphics card (no onboard GFX), the machine will turn on with the fan spinning, but no graphic output. Keyboard was not working too.
My CPU fan is one of those that draws power directly from the 4 pin plug, it ran VERY slow, as in i can see the blades turning, so the PRM should be about 100, way too slow. Does this mean that there is not enough power coming from PSU?
The current PSU is a cheap brand call Young Year. (lol), hardwaresecret has a review on this brand, though its a different PSU model. basically they concluded that its junk -___- (I didnt know this when i bought it a long time ago).
So, can I confirm that the fault lies in the GPU
BTW, i would like to buy a CM extreme power, as i am low on budget and the review seems decent. If not, please recommend me another BUDGET brand. I am poor lol. Seasonic and Crosair are out of my reach.... thx
