I have an AMD Athlon II x4 640 running with a stock cooler. The 640 has a maximum temperature of 70/71 degrees celcius, and runs at 95W. When I looked at the temperatures of the cpu I thought they looked a little hot, idling around 41, and reaching 69 when running the cores at 100% with prime 95. My initial solution was to install some case fans, which are keeping the system temperature at 43 even at full load. However, the processor is still reaching the high 60's (I swear I saw 69 again, but at the moment it is at 66) What jumps out at me, is that the processor is always running at exactly 106.4 W. I have cool' n' Quiet enabled, so I figure that the alternating clock speeds should change the power consumption, and the fact that the power is always 11W over, despite the voltage being a stock 1.4V. I now have a few questions.
Is it normal for the power to be completely unchanging?
What could be the cause of these strange power readings? Faulty sensor?
Could this extra power be the cause for the high heat levels?
And... Is it time for a new cooler? (running this hot almost makes me want to underclock the processor)
Thanks for your time, and here are some screen shots,
Niklas
Niklas
