Solved
Building help
Last response: in Systems
So today i tried putting together my first build. I followed the step by step guild i found on this site as closely as possible... but it didn't work out too well. When it came to connecting the case fans ( CM storm scout), i found cables that had either 4 pins or two. My psu (700w ocz fatality) had cables that were one end molex and the other 4 pin female... so i kinda fitted the 4 pin case fan into it, but the two pin ones wont fit into these.... where do i put them?
After that i decided to just see if everything else was functioning... but the computer wouldn't even boot. It does'nt seem like powers getting through and im almost certain ive connected everything to the right place other than the case fans.
Any help would be much appreciated
More about : building
I find the manuals arent very descriptive, might just be cause im not too familiar with everything... The PSU had a 4 pin and an 8 pin, i connected the 4 pin and left the 8 pin inside... thats supposed to happen right? (1st step)
Related ressources
Thanks prox i got it working :)
Only thing is I cant figure out how the fans work, any ideas? Only the one thats four pinned and connected to the psu through a molex cable works, the other two i dont see where to put cause there two pronged and the cables that came with the PSU are all four.
You need to look at the fans more closely. The two pronged connections are very likely the LED connections and they hook into the LED controller on the front panel. Those two fans should ALSO have seperate molex or 3-pin power connections.
This might just be me but i dont see any 3 pin, i see a lose cable that looks like esata and cant quite figure out what its for (when i got the case there were multiple wires tied together) Also im not quite sure what you mean when you say their for the LED controller... isnt that the button on the front panel? I dont see a separate device in the case to which i could connect the wires to.
Look at the LED fans. These are the two fans that are not black. The black one on the top is NOT LED. These two fans should EACH have two sets of wires coming from them. One cable will go to the LED button on the front panel, the other cable is for the fan motor itself. Can you see both cables?
Ask the community
