Hey All
Planning to build a computer soon but since I'm on a budget I'm trying to cut costs wherever I can.
I was wondering if
[strike]http://www.newegg.com/Product/Product.aspx?Item=N82E16817707005
[/strike]
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341017
This power supply, will be enough to power the computer I plan to build
I'm going to post the video card, cpu, mobo, and case. If there's any other hardware I should post just ask below.
[strike]http://www.newegg.com/Product/Product.aspx?Item=N82E16814127495 (video card)[/strike]
Update: Decided to go with this video card instead since it came in a package with a better power supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102873
[strike]http://www.newegg.com/Product/Product.aspx?Item=N82E16819103286 (cpu)[/strike]
Update: Decided to go with this CPU
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103698
it's cheaper but as pointed out below, the other cpu i was going to get was not compatible with my mobo.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157198 (mobo)
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129042 (case)
For the future, how can I check this myself?
Thanks all.
I was wondering if
[/strike]
Thanks all.
