Need help with size of my power box
Looking to build a new pc, need help with power requirements tho
getting
i7 950
2x Radeon HD6850
4GB RAM
500GB HD
What would be a pretty safe estimate on the power requirements of the system?
6 answers Last reply
More about need size power
  1. 650 will be fine just get a quality brand ,whats your budget?
    lol, not from US, so dont know in dollars... but R10000 :kaola:
    ty for the reponse tho, just needed some sort of yard stick :)
  3. ok did a quick calc based on the price of the i7 950, got about $1175 max to spend
  4. Not sure exactly what's available in your area but Antec, Corsair Seasonic etc. are safe bets.
    http://www.jonnyguru.com
    http://www.hardwaresecrets.com
    are the places to start looking for PSU reviews. If you need further advice on a specific PSU that you're not sure about feel free to post back here.
  5. cool. Looked at the jonnyguru. That didnt have any review of the psus I have available. Looked at 2 cooler masters tho one got a good rating other bad. Also looked at a cougar and that got a good rating.
    These are the 650W psus that are rather cheap:
    Cooler Master Extreme Power Plus - 650 Watt Power Supply Unit
    Cooler Master RP/RS-650-PCAR eXtreme power plus - 650watt - Power Supply Unit
    Cooler Master eXtreme - RS-650-PCAR-E3 - 650 Watt - Power Supply Unit
    And the Cougar (650W) is also available.
    Not really a power box nut, just like gaming, so need a box that will keep me switched on :D
    ty
Power Supplies Intel i7 Build Power Components
