First Gaming PC Build! Need help!
Last response: in Systems
October 13, 2010 7:08:21 PM
CORSAIR CMPSU-650TX 650W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply
G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 533 (PC2 4200) System Memory Model F2-4200PHU2-2GBLA
GIGABYTE GA-EP43-UD3L LGA 775 Intel P43 ATX Intel Motherboard
Intel Core 2 Duo E8400 Wolfdale 3.0GHz 6MB L2 Cache LGA 775 65W Dual-Core Processor BX80570E8400
I'm only looking for a new CPU, PSU, RAM, and MOBO. Are these parts all compatible? Should I be looking at something cheaper?
More about : gaming build
October 13, 2010 7:11:13 PM
What is your budget?
m
l
October 13, 2010 7:12:25 PM
is that your current system or what you are planning to buy? (because its actually close to my current 2-year old system!)
m
l
October 13, 2010 7:13:20 PM
What are the other components that you have?
m
l
October 13, 2010 7:14:50 PM
I actually created this thread for my friend, he's gone to the bank right now but from what I know he already has a case, a gpu on the way and a hard drive.
He just wants to run Counter-Strike:Source and BC2 with good fps.
m
l
October 13, 2010 7:15:40 PM
The main thing is the GPU. Do you know wich one her ordered?
m
l
October 13, 2010 7:16:50 PM
Hmm. I'm not 100% sure at the moment but I'll get back to you as soon as he comes online.
I'm assuming it's PCI-E.
m
l
October 13, 2010 7:25:27 PM
^that's a dual core.
m
l
October 13, 2010 7:29:00 PM
yes i know. to keep him down around $400 dollars. The dual core i5 will work on that mobo. You can to disable the onboard graphics. If he can spare another $25 dollars then up it to the i5 750 for around $450 total
m
l
October 13, 2010 7:44:32 PM
Thanks for the help guys! He made his decision.
m
l
