USB mass storage device not getting drive letter
  • Storage
  • Dell
  • Devices
  • USB
  • Components
Last response: in Components
Anonymous
a b G Storage
January 8, 2011 7:04:06 PM
dell pc running XP just stopped recognizing usb lexar storage unit. dell running vista does ok.
More about : usb mass storage device drive letter
January 8, 2011 8:03:28 PM
I'd check in Device Manager while you plug in and remove the device to see if it's recognised or detected at all. Windows should make a beep type sound when a device is inserted or removed. From the Device Manager you can also update or roll back your drivers to see if that helps.
m
l
