Hello,
I have been thinking of upgrading my computer from my 2002 dell dimension stock(lol), so I need a little help if you all don't mind. I have a $700 dollar budget but would rather keep it to 650 so i can get Civ 5
*I don't need a monitor,speakers,mouse,keyboard, or HDDs. Oh and i have Win 7 64 and 32 bit *
So Far i have:
DVD Writer: LITE-ON 24X DVD Writer Black SATA Model iHAS424-98 LightScribe Support [23.99]
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106335
Case: Rosewill ARMOR Gaming ATX Mid Tower Computer Case [99.99]
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147047
GPU: Palit NE5S4500F0601 GeForce GTS 450 (Fermi) 1GB 128-bit GDDR5 PCI Express 2.0 x16 HDCP [129.99]
http://www.newegg.com/Product/Product.aspx?Item=N82E16814261078
RAM: G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) [84.99]
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231277
MoBo: ASUS P7H55-M PRO LGA 1156 Intel H55 HDMI Micro ATX Intel Motherboard [89.99]
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131623
Intel: Intel Core i3-530 Clarkdale 2.93GHz LGA 1156 73W [113.99]
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115222
PSU: Im not sure if I should go 430 or 500 watt
Total Price: 542.94
I guess my questions are:
1. What should i get for wattage on my PSU?
2. Should I get a mATX or standard ATX for the motherboard?
3. Is everything compatible?
4. Im going to be video editing using Black Magic Intensity via PCI slot, will I be able to do enough with only a 1TB HDD and a 80GB one? Or should i get a few 250 or 500 HDDs?
Thank you guys for all your advice and input!
So Far i have:
Total Price: 542.94
