Solved
Monitor size and frame rates?
I just went from a 22 inch to a 26 inch monitor and my fps dropped somewhat, is this typical?
2 answers Last reply Best Answer
More about monitor size frame rates
  1. Best answer
    It is perfectly normal if your resolution increased.
    The higher the resolution, the more pixels the GPU is responsible for, with more work having to be done you will get a lower fps.
  2. Best answer selected by jijoslin.
Radeon Monitors FPS Graphics
