G
Guest
Guest
Hello, I have been a computer gamer for many years, but have not had the confidence to tinker around on the inside of the case before. I have some money I'm willing to shell out and it seems a better idea to build than to buy. My budget is around $1,000 and I've been doing alot of research on the internet to prepare me for my first build. My questions are with the components listed below does it look like they are all compatible, also does it look like with the components involved does it look to you like I'd be getting the most "bang for my buck" as it were. Thank you in advance for your input.
Case - XCLIO Blackhawk Color Full Tower Case - newegg - $130
MOBO - ASUS M4A890GTD-PRO/USB3 - Tiger Direct - $150
CPU - AMD Phenom II x4 965 Black Edition - newegg - $160
RAM - GSKILL Ripjaws 4GB (2x2) 1333 - newegg - $80
CPU COOLER - Corsair H-50 liquid cooler - Tiger Direct - $80
GPU - HIS Ice-Q Radeon 5770 1GB - Tiger Direct - $150
HDD - Western Digital Caviar Black 640GB 7200rpm WD6402AAEX - newegg - $70
DVD/RW - LG GH22LS50 DVD/RW (sata) - Tiger Direct - $22
OS - Windows 7 Home Premium 64bit (oem) - newegg - $100
Memory Cooler - Kingston KHX-FAN Hyper X Memory Cooling Fan - Tiger Direct - $25
Total Build $1062 + shipping
I was thinking of getting another Coolmax CMF1225 BL 120mm fan for the back panel of the case for exhaust as I don't think this one has a rear fan included.
I should also mention that I'm a gamer but don't need anything more than 1 vid card atm although would like to add crossfire later...and am looking for the build to be functional/future proof, as well as asthetically pleasing. Thanks again!
