hey everyone i just got all my stuff from newegg and been trying to put it all together.. here is list of my parts
NZXT M59 Case
COOLER MASTER Hyper 212 Plus
SAMSUNG Spinpoint F3 HD502HJ 500GB 7200 RPM SATA 3.0Gb/s 3.5"
CORSAIR XMS3 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
AMD Phenom II X4 955 Black Edition Deneb 3.2GHz Socket AM3 125W
OCZ Fatal1ty OCZ550FTY 550W ATX12V
GIGABYTE GV-R585OC-1GD Radeon HD 5850 (Cypress Pro)
GIGABYTE GA-880GA-UD3H AM3 AMD
ok so everything is plugged in and heres where the problem starts
When i power it up, LEDS and fans all work.. so psu is ok
Everything attached to MOBO however does not work, monitor, mouse, keyboard, etc... maybe MOBO problem?
The Cooler fan attached to CPU works fine... so maybe mobo is ok? or its just the power flowing through it?
the HDD spins up so thats ok too i think
Possibly a RAM problem? everything should be compatible
When i test just the MOBO and cpu with monitor plugged into mobo i can get to a screen that says
OS Loading, then an error message, but probably because i unplugged the HDD
but when i try to plug in the keyboard, the screen goes away... ??
but at least getting to a screen would mean that the CPU is ok??
i tried taking everything out and putting back in but no result
plz advise... very confused..
MoPo
NZXT M59 Case
MoPo
