I'm trying to fit my new GTX 460 into my case but there is a connector in the way. Looks like the blue cable is going from the CD/DVD drive to a slot on the motherboard labeled "SATA2_2." My new card can't get into it's slot because this the cable is in the way.
There are other blue connectors out of the way titled "SATA2_5" - can I just move the blue connector that's in the way over to those ones?
I'm not too technically saavy so sorry if this is a dumb question. Here are some pics, thanks for the help:
