I'm helping a friend configure/build a new system, and would appreciate some feedback. He'll be using it for HD video editing and gaming (Half Life 3, when it comes out).
Case: Antec Nine Hundred Black Steel ATX Mid Tower Computer Case
Power Supply: CORSAIR HX Series CMPSU-850HX 850W
Motherboard: MSI 890FXA-GD70
CPU: AMD Phenom II X6 1090T Black Edition Thuban 3.2GHz
GPU: XFX HD-597A-CNB9 Radeon HD 5970 Black Edition 2GB
RAM: Mushkin Enhanced Ridgeback 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 2000 (PC3 16000) Should I consider going with 8GB?
Primary HD: Crucial RealSSD C300 CTFDDAA064MAG-1G1 1.8" 64GB SATA III MLC Internal Solid State Drive (SSD)
Secondary HD: SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive
Blu-Ray Burner: Pioneer Black 12X BD-R 2X BD-RE 16X DVD+R 5X DVD-RAM 8X BD-ROM 4MB Cache SATA Internal Blu-ray Burner Blu-ray Disc/DVD/CD Writer BDR-205BKS
Will also need a wireless adapter (computer will not be in the same room as the router). I'm used to using Linksys, however reviews on their adapters haven't been that great lately... Should support G/N. Any thoughts?
His budget is ~$1500, but with Win 7 this build is just under $1950. He's expecting not to have any compromise in performance....he recently purchased a 23" monitor, and wants no glitches when watching HD video on Vimeo...in multiple tabs..full-screen (probably while encoding HD videos and firing up itunes at times). I typically reboot before and after gaming/encoding, which he doesn't. All reasons for going a bit overboard on hardware.
Thanks for any input, the plan is to order all of the components in the next 2-3 weeks.
