Sign-in / Sign-up
Closed
Power switch pins
  • Prebuilt
  • Front Panel
  • Power Switch
  • eMachines
  • Systems
Last response: in Systems
October 15, 2010 8:50:28 PM
Hello, Can anyone please tell me the pin layout for power switch on mb for T2778 emachine. The pins are lined up horizontally with 4 on top then 5 next then 3 on bottom. A confused senior citizen trying to get friends computer running. I didn't write down how they were hooked to front panel wires. I would appreciate any help given. Either written description or picture. Thankyou.
More about : power switch pins
Best solution
October 15, 2010 11:39:01 PM
I found a a diagram of your front panel pinout. Here are the pins as you described:
0000
00000
000
First, ignore the bottom three pins. They are for an IR receiver.
Now, I'm going to number the two top rows of pins to help guide you:
1234
56789
The power switch connects to pins 3 and 4. Pins 7 and 8 are for the reset button. Your hard drive LED connects to 5 and 6. The power LED connects to 1 and 2. You must have the "+" and "-" for the LED wires correct so if it doesn't light up then switch the wires. For the power and reset switches, it doesn't matter if the wires are swapped.
Summary:
1-2 is power LED
3-4 is power switch
5-6 is HDD activity LED
7-8 is reset switch
Hope this helps.
October 16, 2010 3:50:14 PM
Thank you very much. Also appreciate the quick response.
mrceeky
_____________________________________________________________________________________________
0000
00000
000
1234
56789
Summary:
1-2 is power LED
3-4 is power switch
7-8 is reset switch
Hope this helps.
Score
October 23, 2010 1:40:58 AM
Best answer selected by mrceeky.
Score
November 27, 2011 12:49:29 AM
this is what I found after much searching ,.. I have a used Dell MB #
E210882 c23438-403 ,... not sure what it came out of . it has 4 ,..184 dimms slots 1, AGP , 3PCi slots , onbrd vga, lan, 5 plug onbrd sound,. came w/ p4,.. 2.6 or celeron 2.66 (478 socket) the front panel pins are on "J7J2" and here is a site with info....http://forums.pcworld.com/index.php?/topic/16633-dell-d...
GL i had heck of a time finding this info
Score
February 3, 2013 10:16:49 PM
0000
00000
000
1234
56789
Summary:
1-2 is power LED
3-4 is power switch
7-8 is reset switch
Hope this helps.
This sounds like what is on my dell dimension 4600 motherboard that stopped working. If you could help me find the manufacturer of the motherboard I would greatly appreciate. I'm prepared to do some hard core troubleshooting because this was a real good motherboard.
Regards.
Score
