G
Guest
Guest
Hello, I just recently purchased the parts to build a new PC and assembled them all today. This is my 4th build but I concede I am far from knowing everything about building. When I hooked everything up I could not find any light on the MOBO to show that it had power but it's a new one so I assumed it didn't have one. When I press the power button the fans and LEDs spin and light up but the instant I release the button it shuts off. If I hold the button down for a few seconds the PSU sort of clicks and the fan doesn't spin but jerks a bit. The other fans and LEDs appear to sputter or flicker.
I did the test where you short out the green wire on the 24 pin connector to see if the PSU powers up without being connected to anything. It came on just fine. The PUS is not new as is everything else in my system. It worked on my previous system just fine and I am positive it is powerful enough @750W. From what I have read on here it could be a short somewhere but even when I unhook all but the CPU, HSF and PSU it does the same thing. If I can diagnose the problem it won't be too big a deal to replace the parts. I bought them all from newegg so I can RMA and though I would be out the shipping costs its better than being out the whole cost of the part.
I guess it was inevitable that I would run into building problems at some point. They can't all go perfect.
My System:
AMD Phenom IIx3 740 BE
MSI 770-G45 ATX AM3 MOBO
G.Skill Ripjaws Series DDR3 1333 CL7
EVGA Nvidia GTX 460 GPU
WD Caviar Blue 500GB 7200RPM HDD
Cooler Master Real Power Pro 750w PSU
My System:
