I just purchased a 2x4 GB Corsair Low Vengeance kit. It's rated to run at 1600 MHz, 9-9-9-24 at 1.5V.
My motherboard is a GA-MA790GPT-UD3H, CPU is Phenom II X4 955 BE.
If I set the FSBRAM ratio in the BIOS so that the memory runs at 1600 MHz, and have the timings on auto, the system will boot but the timings will be at 11-11-11-31 instead of 9-9-9-24... but that isn't the problem.
With this kit, whenever I try to change the timings from "auto" to "manual" in the BIOS (WITHOUT even changing any values), the system will not boot. With the timings at auto, it defaults to 1333 MHz at 9-9-9-24 with 1T and boots. I want it at 1333 MHz at 9-9-9-24 at 2T... yet it won't boot with those settings for some reason. Voltages are the same for both.
Even if I manually set every timing to the slowest possible value, the system still will not boot unless the timings are at AUTO.
Any ideas? (I have the latest BIOS).
