G
Guest
Guest
APPROXIMATE PURCHASE DATE: This Week in USA
BUDGET RANGE: ~$1100, the current build below is at my max but I'd like to see if I'm missing performance or leaving money on the table.
SYSTEM USAGE: Dedicated system for triple monitor set up for iracing.com (a Direct 9X game), fps and reliability are key for me.
PARTS NOT REQUIRED: keyboard, optical, mouse, monitors (3x 22" WS), speakers
PREFERRED WEBSITE(S) FOR PARTS: Newegg
PARTS PREFERENCES: AMD
VIDEO CARD: Reading good results on iracing forum w/5870 setups.
OVERCLOCKING: Would prefer to use components within their reliable parameters as I'm a noob. If I need to worry about cooling, please recommend...
CROSSFIRE: If needed, to support the res I'd be pushing. Or, for future-proofing.
MONITOR RESOLUTION: 5760x1080 if feasible at this price point
ADDITIONAL COMMENTS: Windows 7 64 bit. I think I'll also need an active VGA-DVI adapter to support the third screen if I've researched correctly.
Thank you very much for any help you can offer.
Current Build:
Sapphire 5870 Video
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102883
AMD Phenom 970
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103894
Asus M4A89TD Mobo
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131655
G.Skill 4GB RAM
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231303
1 TB SATA
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136534
Azza Full Tower
http://www.newegg.com/Product/Product.aspx?Item=N82E16811517004
Rosewill 700W PSU
http://www.newegg.com/Product/Product.aspx?Item=N82E16817182173
CPU Cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233029
WIN 7 64-bit Home
Active Display Port Adapter
http://www.newegg.com/Product/Product.aspx?Item=N82E16814999030
Thank you for your constructive criticism.
Current Build:
Sapphire 5870 Video
AMD Phenom 970
Asus M4A89TD Mobo
G.Skill 4GB RAM
1 TB SATA
Azza Full Tower
Rosewill 700W PSU
CPU Cooler
WIN 7 64-bit Home
