Putting my e8400 system in daughters' room and have these parts on wish list for next month purchase:
Intel Core i7-2600K
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115070
ASUS P8P67 EVO LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131695
Antec TruePower New TP-750 Blue 750W Continuous Power ATX12V V2.3 / EPS12V V2.91 SLI Certified CrossFire
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371022
CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ8GX3M2A1600C8
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233147
Western Digital Caviar Black WD5002AALX 500GB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136795
CORSAIR Hydro H70 CWCH70 120mm High Performance CPU Cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835181013
COOLER MASTER Storm Scout SGC-2000-KKN1-GP Black Steel / Plastic ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119196
Questions:
Is the mother board good enough for high oc's and will it go good with the memory?
Is the power supply good enough if I decide to go SLI on a pair of gtx's 570?
Should I spend Alot more money on a SSD or stick with this regular drive?
Is the water cooling good enough ?
Intel Core i7-2600K
Questions:
