Hey I have a Annoying Problem with my ram and motherboard. My Motherboard is a GA-790xta-UD4, which is Supposed to run 1600Mhz Ram. With 2 Sticks off Crucial Ballistix Tracer 1GB 1600Mhz Ram it runs fine. I Bought another Two sticks of the exact same ram and installed them and now i get ram errors and BSOD every now and then if i run at 1600Mhz. I currently am running my ram at 1333Mhz and its flawless. I have run Memtest86 for hours with with both sets of ram individually at 1600Mhz and all four at 1333Mhz no problems. With 4 at 1600Mhz problems almost instantly. After Researching online i found this board is quite notorious for its Various problems. I was Wondering If i overclocked my FBS or My North-Bridge would it help or if there is something else you could recommend it would be great. I have though about increasing ram voltage to increase the stability of the ram but as far as i know it appears to be more of a motherboard thing. Any input would be reat before i go messing around in the bios. Thanks in advance.
