G
Guest
Guest
Hi all,
Got my new build rolling today
All gone well until i tried to get any audio; it plays but there is a lot of crackling.
After installing the OS I then installed all the drivers that came with the motherboard. Ive also pulled down all windows updates.
Sound from both the case and the motherboard itself are identical with the crackling. Ive tried plugging the HD audio connector from the case to the motherboard, the AC97 and also with no connections from the case audio to the motherboard. All the same results, with the sound coming directly from the motherboard jack being just as bad.
Im sure its a driver issue but struggling to find any good info.
Ive tried the latest realtek drivers from ASRock (2.62) and the latest drivers from Realtek (2.65) but with no luck.
Device manager shows no yellow exclamation marks. Under Sound controllers in device manager I have four entries for NVIDIA high def audio, and one for realtek high def audio.
Im on Windows 7 64 bit.
Any help on this would be a godsend.
