It's been a long time since I've built a PC...so I'm 99% sure I'm right - just want to make sure before I make this swap. I got a free e-Machines PC (2.1ghz Core2Duo, 1GB ram) that I plan on making into my 3rd XBMC HTPC box...So I wanted to put the guts into a better "HTPC Friendly" case.
The eMachines model # is T52324
Mobo page is here I believe: http://www.e4allupgraders.info/dir1/motherboards/socketam2/ecsMCP61PM-AM.shtml
I want to throw it into this case:
http://www.amazon.com/gp/product/B004GGUAUE/ref=pd_lpo_k2_dp_sr_1?pf_rd_p=486539851&pf_rd_s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B0011UDQYA&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=0XZSCNZTHS1PZZZFB461
This should work, right? I'm assuming any MicroATX mobo should fit into this case since it accepts MicroATX. The last PC I've actually built was back before dual cores were even around I'm still a nerd, just have bought pre-built machines since I'd rather not spend the time to piece my machines together.
