Closed
Sapphire 5670, not working! Please help!
August 31, 2010 3:20:14 AM
I just received my ATI Sapphire 5670 DDR5 512mb http://www.newegg.com/Product/Product.aspx?Item=N82E168... in the mail today. Installed it but failed. I have no clue why it won't work. When I have it all hooked up and turn on my pc a little message box comes up and says "Monitor is working. Activate by computer.". But then when I hook up my old card it works fine! It's pissing me off.
My motherboard (Intel i945P/PL/G/GZ) is compatible with this card, I believe.
I really don't understand what's wrong with this video card. Did I get a DOA card?
More about : sapphire 5670 working
Anonymous
August 31, 2010 3:54:32 AM
if you have plugged everything right and u get the error then you got a dead card
Score
Best solution
August 31, 2010 10:10:26 AM
then try your card in different PC, if it's failed again then you got a bad card...
August 31, 2010 11:47:09 AM
Did you do a proper uninstall of the old card before installing the new card?
Score
August 31, 2010 2:13:30 PM
Yes, I did everything right, but not to avail. If it's a dead card, I hope newegg does returns...
Score
September 9, 2010 11:59:36 PM
Best answer selected by imanoob93.
Score
September 10, 2010 12:01:00 AM
This topic has been closed by Mousemonkey
Score
