I have recently built a new computer and i am having teething issues, i am completely confused about the cause of these problems. i would be grateful if anyone could help.
the first of my problems is that sometimes when i turn my pc on the fans on the outside light up the cpu fan starts but nothing happens on the screen. "loading asus express gate" doesn't even appear. sometimes holding down the power button turns the computer off. sometimes it dosn't work. when this happens normally i need to wait 10 minutes then when i turn it back on it works fine.
Another problem i have had is that the computer can randomly freeze when not in a full screen game. it has happened running itunes and on safari or even when welcome appears on startup. i know my pc is not overheating as under lode in mafia 2 the core temp is always below 50 Celsius using stock heat sink and paste. i have Installed all updates including graphics drivers. i cant remember this happening before updated the bios in asus update.
all components in my pc are if this helps
1 x Casecom 6788 Black Mid Tower Case with Full Black Interior/Exterior 120mm Blue LED Front Fan - No PSU
1 x Samsung HD103SJ Spinpoint F3 1TB Hard Drive SATAII 7200rpm 32MB Cache
1 x Corsair 4GB DDR3 1333MHz Memory Module CL9(9-9-9-24) 1.5V Unbuffered Non-ECC
1 x OCZ Stealth Xstream II 600W PSU - 3x SATA 2x PCI-E 204353 Invoiced Track
1 x Microsoft Windows 7 Home Premium - Licence and media - 1 PC - OEM - DVD - 64-bit - English
1 x AMD Phenom II X4 965 Black Edition 3.4GHz Socket AM3 8MB L3 Cache 125W Retail Box Processor
1 x Asus M4A87TD/USB3 870 Socket AM3 8 Channel Audio ATX Motherboard
1 x Nexos Molex Hub - Turn 1 Molex into 4 - Blue LED Light Effect
4 x 120mm Blue LED Fan - 4pin Molex Connection
1 x Arctic Cooling Freezer 7 Pro rev 2 Socket 775, 1156, 1366, AM2, AM3 Heatpipe CPU Cooler /not installed
1 x PALIT GTS 450 SONIC OC 1024MB GDDR5 Dual DVI VGA HDMI Out PCI-E Graphics Card
1 x Startech 4 Pin P4 CPU Power - Extension Uk
Any replies would be greatly appreciated, thanks
