My whole system is listed here: http://www.tomshardware.com/forum/296329-31-1300ish-parts-reused#t2196546
I put everything together and turned it on, lights and fans went on, but it didn't beep and didn't boot to the bios or anything. I took out all the RAM and tried again, still no beeps. My motherboard has this thing called "Dr. Debug" which is supposed to tell you what any problem it, but mine said 00 which I believe means it should be working. Is the motherboard just bad?
As for the beeps, I'm not sure if they simply weren't programmed in because they have this "Dr. Debug" thing.
One other thing I might be concerned about is that the Mobo says it supports X4, and says it is X6 ready or something like that. I'm using an X6. What is the difference?
Please help, thanks.
