Sign-in / Sign-up
Power supply and case - recommendation ?
  • Power Supplies
  • Cases
  • Components
  • Product
Last response: in Components
January 12, 2011 11:58:00 AM
Hi guys, I am building a computer using 2500K and either 6870 or GTX560.
I am not planning SLI or crossfire.
how much Watt power supply do you think is sufficient?
and what brand do you recommend? any links?
When it comes to cases, I think I will go with full tower but there are so many diff kinds and don't know which one to get. Is there any legit case with reasonable price and quality? thanks.
More about : power supply case recommendation
a b ) Power supply
January 12, 2011 12:13:56 PM
^^^Good PSU...
You cant go wrong with http://www.newegg.com/Product/Product.aspx?Item=N82E168... ... but you wont be requiring this unless you have some other serious components...
For $2500 budget you can go for the best of the case... mid tower go for Silverstone FT02... Full tower then nothing but Haf X...
m
l
