Hello
so i got my new corsair vengeance memory in, it is the 8gb pack low profile (i got 2)
anyways here the problem when i first installed the memory it was not running close to 1600mhz
so i clocked it up and i did necessarily changes, making sure timings were right comand rate, voltage i left at 1.5v
and when i go into windows everything seems fine but after a half our or so of gaming i blue screen, this happens all the time
any idea to what might be causing system instability?
(i tried increasing voltage still didn't work)
System Spec:
CPU: Amd Phenom ii 1100t w/ Thermaltake Frio OCK (4.0ghz)
Mobo: Asus m4a89gtd pro/usb3
RAM:Corsair Vengeance 1600mhz 16GB LowProfile
PSU: Kingwin Lazer 1000w
GPU: Amd His Turbo 6970
System Spec:
